 Post subject: Urgent! Weird Winstep Popup
PostPosted: Mon Jul 30, 2018 9:02 am
What the heck?!!! I just got a Winstep popup the likes that I've never seen!
It refers to an external drive. Why would Winstep give such a message? Should I click no or go ahead and empty it?
Here's a screenshot of it.
 Post subject: Re: Urgent! Weird Winstep Popup
PostPosted: Mon Jul 30, 2018 9:14 am
That's not a Winstep message, that is a *Windows* message. And it means exactly what it says.
If you answer yes, all the contents in the Recycle bin *for that drive* are deleted and the Recycle bin structure is re-created.
PostPosted: Mon Jul 30, 2018 9:44 am
Hmmmmm, the message has a Winstep logo. Here's a screenshot of it on the taskbar. If it's a Windows message, why the Winstep logo?
PostPosted: Mon Jul 30, 2018 9:47 am
Probably because that dialog was created from within the Winstep process. It is still a dialog generated by Windows itself.
Just google 'the recycle bin is corrupted' and see for yourself. :)
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot], Picco14 and 61 guests
