 Post subject: WorkShelf is showing up in NS Taskbar
PostPosted: Sat Jul 21, 2018 8:33 am
Jorge, I'm sure restarting will make it go away, but any idea why WorkShelf would be showing up in the NS Taskbar? I've attached a screenshot.
 Post subject: Re: WorkShelf is showing up in NS Taskbar
PostPosted: Sat Jul 21, 2018 3:24 pm
LOL. Well, I have NEVER seen that happen. I have never had anyone else complaining about it either.
Looks like *something* in your system changed the properties of the WorkShelf 'windows' to something that would show up in the taskbar. What happens if you temporarily disable NS task management, does it also show up on the Windows taskbar?
PostPosted: Sat Jul 21, 2018 5:38 pm
Well, I switched themes to see if the icon color theme was specific to the theme and the WorkShelf modules disappeared from the taskbar. Switching back to K-TEK 4D didn't bring them back. If it happens again I will try disabling NS task management.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot] and 88 guests
