 Post subject: Winstep only recognizes two monitors
PostPosted: Wed Jul 18, 2018 3:20 pm
Hello.
First, I would like to state that I just love this software. Recently, I bought a third monitor, and now, winstep doesn't seem to recognize it. Is there a way to fix it?
Thanks in advance!
 Post subject: Re: Winstep only recognizes two monitors
PostPosted: Wed Jul 18, 2018 6:57 pm
What Windows version? Do all the monitors share the same screen DPI? Did you restart the software already? Are they configured as independent monitors in Windows or are you using something like nVidia's Surround?
PostPosted: Wed Jul 18, 2018 8:57 pm
The version in windows 10. I already restarted the software a few times and I'm not using nvidia surround. The threee of them use 1920 x 1080.
Thanks for your answer.
PostPosted: Wed Jul 18, 2018 11:20 pm
Which of the 3 monitors is not showing up?
The screenshot you provided does not show me their relative position either.
PostPosted: Thu Jul 19, 2018 11:13 am
Hello! The monitor that doesn't show would be the numer 3, LED-2151.
PostPosted: Thu Jul 19, 2018 5:51 pm
I will have to compile a small applet to try and figure out what is going on in there. I'll let you know here once you can download it to give it a try.
PostPosted: Thu Jul 19, 2018 6:58 pm
Thanks a lot, my friend!
PostPosted: Thu Aug 02, 2018 1:13 am
Ok, apologies for the long delay.
Download TestMonitors.zip from HERE, unzip, then run TestMonitors.exe and post a screenshot of the results.
PostPosted: Thu Aug 02, 2018 1:33 pm
Actually you don't even need to post a screenshot, you can simple copy & paste the information here. :)
PostPosted: Wed Mar 13, 2019 2:38 pm
Hello! Sorry about the delay. I got it working, somehow. But now, I changed my RIG and I have the same problem again. Here are the results. Thanks in advance.
Generic PnP Monitor: (-1920,0) - (1920,1080)
Generic PnP Monitor: (1920,-116) - (1920,1080)
Generic PnP Monitor (Primary Monitor): (0,0) - (1280,720)
PostPosted: Wed Mar 13, 2019 2:59 pm
Change the DPI of your primary monitor to 100%.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot], Picco14 and 59 guests
