 Post subject: So, Can Anybody Help with Workshelf Config?
PostPosted: Mon Jun 11, 2018 4:51 pm
I am trying to use the newer Workshelf Advanced Skinning mode with WsFullBody.*, WsFullTabI.*, WsFullTabA.*, WsFullTabmL.* and WsFullTabmR.* - but what are the correct configurations for this in the *.wsw file? With the settings for the old-style multi-bitmap shelf, it yields just visual gobbledygook. Any help appreciated, thx.
How will it all end?!
IN FIRE!
 Post subject: Re: So, Can Anybody Help with Workshelf Config?
PostPosted: Tue Jun 12, 2018 2:24 pm
Use BodyLeftTile, BodyRightTile, BodyTopTile and BodyBottomTile for the WsFullBody bitmap.
The icons will start appearing AFTER the above tile sections, so these can be used in conjunction with BodyRightOffset and BodyLeftOffset (which can be negative numbers) to offset the icons.
For tabs use ATabLeftTile, ATabRightTile, ITabLeftTile, ITabRightTile
Luckily for you I just started working on the skinning part to be able to make those pesky inverted Shelves, so I had to look this up again anyway. :wink:
PostPosted: Tue Jun 12, 2018 4:06 pm
LOL! Aww thanks a mill Jorge - just seemed absurd to use the old format with 17 separate bitmaps when I've got all the 5 bitmaps required for the newer format anyway and when the older format is meant to be 'heritage' only - i.e., to support old skins. I thought it's all the more important to use the newer format on account of the multiple shelves that you are so busily working on.
Btw, I think I may have come up against a possible bug, not sure if it's been reported before and not sure whether it's perhaps new to 18.5. I was using one of my (background, not tiled) docks to launch an app but accidentally clicked on the area roughly between icons. 'Pouffff....' The icon of the app I meant to hit went up in smoke, leaving its sub-dock abandoned and likewise deleted. Repeated this on another background dock, same thing. Then tried a tiled dock - nothing happened there. So would seem to only affect background docks. (Thx to up to date backups, no losses, all safely restored.)
Oh, and the new delete anim came in very handy there, as it immediately drew my attention whereas otherwise I would have just been left wondering what happened to my icon and sub-dock! :)
IN FIRE!
PostPosted: Tue Jun 12, 2018 5:01 pm
doesnt happen here, only simmilar thing that happens if i accidentaly g'grab' an icon for drag and drop
PostPosted: Tue Jun 12, 2018 5:10 pm
Probably what happened, because I can't reproduce it here either - in which case it created a shortcut on the Windows Desktop, even if you have 'Hide Desktop Icons' enabled. Nexus supports true drag & drop, so you can drag shortcuts off the dock into Explorer windows, the desktop, etc...
PostPosted: Tue Jun 12, 2018 8:13 pm
Yes, that's got to be it, esp. as the icons are rather large and the separation relatively small. My mistake. Good to know though it isn't some bug.
IN FIRE!
Users browsing this forum: Apple [Bot], Google [Bot] and 15 guests
