 Post subject: Moon Phase Oddity
PostPosted: Sun May 20, 2018 10:59 am
When using Advanced Skinning with the Moon Phase mod, something odd happens with the x-axis text alignment - it doesn't work as one would expect, i.e., set all the same values and each line has a different alignment. Experiment with the values and eventually you get the text to align left.
However, as soon as, say, you exit Winstep and restart it, all the alignments seem to have gone to pot again until you change to another theme and then back. But as soon as a value in a line of text changes, yep, that line goes out of alignment again.
All this leads me to believe that the default text alignment is 'centred', am I right? Which raises the question, can we change that and if so, how?
 Post subject: Re: Moon Phase Oddity
PostPosted: Sun May 20, 2018 11:39 am
Ric, please send me your Moon theme file (.WSL) to the Winstep support address so I can have a look.
PostPosted: Sun May 20, 2018 12:05 pm
Bonjour Nexter...
To align the text put the value "0" instead of "1" to all the lines :
MoonPos01=0
MoonPos02=0...
Warmly...
Picco14.
PostPosted: Sun May 20, 2018 12:17 pm
It shall be on its way to you in about five Jorge. :)
PostPosted: Sun May 20, 2018 12:22 pm
Picco14 wrote:
Bonjour Nexter...
MoonPos01=0
MoonPos02=0...
Warmly...
Picco14.
Bonjour Picco,
Merci beaucoup par votre aide! :)
At least, I hope I got that at least half right without google translate - Thank you so much for your help! :)
That should do it nicely. I'm a happy bunny!
PostPosted: Sun May 20, 2018 12:47 pm
That's fixed things nicely, many thanks to Picco! :)
Users browsing this forum: Apple [Bot], GPT [Bot] and 59 guests
