 Post subject: Holy @$%*
PostPosted: Sat May 19, 2018 12:21 am
Jorge I have to say you've been busy!
My 1 computer is using version 14 of Winstep Xtreme. My laptop is using the newly purchased ver 18.3
You have added so much into this that I'm feeling like Alice stepping through the looking glass. Even more so since it took me an hour to find the "do not launch multiple sessions option" (I use a lot of browser profiles) :lol:
Well done!
Now I've got to ask..
There is an "Apps" and a "Template" menu/shelf and I'll be dipped if I can get them to actually do anything. I'm using Win 7 so that may play into it...
What are they for?
Have a great weekend.
John Strasser
Ph: 480-273-8798
Scottsdale, AZ USA
 Post subject: Re: Holy @$%*
PostPosted: Sat May 19, 2018 3:10 am
Yesss sir! :)
johnstrasser wrote:
There is an "Apps" and a "Template" menu/shelf and I'll be dipped if I can get them to actually do anything. I'm using Win 7 so that may play into it...What are they for?
Apps is for Windows 10 UWP Apps, so it will be empty on non-Windows 10 PCs.
Templates goes back to the Win9x days, where there was a folder containing blank document templates. Probably not even used anymore.
Thank you, you too! :)
Users browsing this forum: Amazon [Bot], Google [Bot] and 56 guests
