 Post subject: Post your Winstep UI
PostPosted: Thu May 03, 2018 2:15 pm
You may have it at default settings, or you may have done something original that will give other people new ideas to customize their UI (or even new ideas for devs to improve the program).
Anyway no harm can come, so let me make the start...
Do not do to another that which you would abhor being done to you, that is the law. All the rest is legal commentary.
Paulo Coelho, Warrior of the Light
 Post subject: Re: Post your Winstep UI
PostPosted: Thu May 03, 2018 2:19 pm
All programs maximized get the full screen (firefox, explorer etc), and the docks appear on screen bump. The moon is the widget, and when mouse bumps top left corner I switch apps.
https://imgur.com/a/U43aWao
(sorry, could not find how to embed...)
PostPosted: Thu May 03, 2018 3:05 pm
Fixed that for you but left the original URL so people can see if full size.
PostPosted: Fri May 04, 2018 2:55 pm
http://prntscr.com/jdppxr
workshelf and subdock in tiop right expanded
http://prntscr.com/jdpqol
unfortunately my screngrab app/site uses img adreses waaaay to long for imbeding
PostPosted: Fri May 04, 2018 3:17 pm
:P :D
PostPosted: Fri May 04, 2018 6:28 pm
:P :D
whaaat? :D lat time i tried to imbed from there i just got garbage
PostPosted: Fri May 04, 2018 7:22 pm
Yes, grasshopper, I know... :) They deliberately return the whole image as a huge data stream, instead of the URL to where the image is stored. However, if you right click and select 'Image Info', at least on Firefox you get the real URL among all the other info. :P
PostPosted: Fri May 04, 2018 8:12 pm
didnt think of that, thought that WAS real URL :)
PostPosted: Fri May 04, 2018 8:16 pm
I did too, until I tried to paste it into notepad. That didn't go so well. :)
PostPosted: Sat May 05, 2018 1:15 am
btw if anyone wonders my heavy use of docks and subdocks comes with 229 kb worth of settings backup
PostPosted: Sat May 05, 2018 11:24 am
Which used to take nearly two minutes to restore until I sped up the restore process by 400% or more lol
Users browsing this forum: Google [Bot] and 60 guests
