 Post subject: Calendar module
PostPosted: Mon Mar 19, 2018 10:30 pm
I'm trying to create a calendar module for a new theme. What is the filename, WsCal.png?
 Post subject: Re: Calendar module
PostPosted: Mon Mar 19, 2018 10:42 pm
Hey Mindy! :)
Here, read THIS, it probably has all the information you need to skin the calendar module (and the battery module too).
Modules in WorkShelf are getting a lot more flexible (I've been changing the format while still allowing it to remain backwards compatible), but that also makes them harder to skin by editing INI files.
PostPosted: Mon Mar 19, 2018 10:56 pm
Thank you. I remembered you gave me this info before, and it made no sense to me. I couldn't find it today though. I am going to give it a try. I really miss making themes for Winstep from others WindowBlinds! I never realized you could open the configuration files in a Winstep theme and change them like an ini file. I'm going to try.
PostPosted: Mon Mar 19, 2018 10:59 pm
That's actually the normal way of making skins.
I think only WindowBlinds and Winstep ever had GUI skinning options. Not sure if RainLender has them too.
PostPosted: Mon Mar 19, 2018 11:14 pm
Rainlendar uses ini files and I am familiar with them. So I am going to give it a try. Thanks again.
PostPosted: Mon Mar 19, 2018 11:18 pm
Feel free to ask questions if you have any doubts. :)
Users browsing this forum: Apple [Bot], Google [Bot] and 15 guests
