 Post subject: How to made png animated icons?
PostPosted: Thu Feb 15, 2018 7:02 pm
I have png images, but I cant make animated png. Nexus icons have big dimension. How I can to do the png animation to work on winstep nexus? Any programs?
 Post subject: Re: How to made png animated icons?
PostPosted: Thu Feb 15, 2018 7:08 pm
You can try working on each frame of the animation as an individual PNG image and then join all the frames together into a single horizontal strip using something like THIS (haven't tried it though, if that doesn't work just Google 'join png images').
Just remember, each frame in the animation must be square (i.e; width of the image is the same as the height) and all frames must have the same dimensions.
PostPosted: Thu Feb 15, 2018 7:20 pm
Thank you, this is working, i got animated icon.
Users browsing this forum: Google [Bot] and 21 guests
