 Post subject: Exporting themes??
PostPosted: Tue Jan 02, 2018 9:09 pm
Can someone educate me on exporting a theme from winstep so I can share it with others?
 Post subject: Re: Exporting themes??
PostPosted: Wed Jan 03, 2018 4:00 am
Sure. I assume the theme you want to export is inside
C:\Users\Public\Documents\WinStep\Themes\
right? If so, lets assume the name is MyTheme. Go inside
C:\Users\Public\Documents\WinStep\Themes\MyTheme\
select *all* the files in there, right click -> Send to -> Compressed (zip) folder
Now rename the resulting zip file to MyTheme.zip, then right click on it and select 'Convert to Xtreme'.
You can now share the theme with other people, and it will auto-install when doubled clicked on.
PostPosted: Wed Jan 03, 2018 6:43 pm
Beautiful, gotcha!
Users browsing this forum: Apple [Bot] and 15 guests
