 Post subject: Winstep Nexus Dock keeps going behind windows 10 taskbar
PostPosted: Wed Dec 27, 2017 1:42 am
Hey, a few problems with my nexus dock i cannot figure out (been using it for a few years now with annoying fixes)
https://gyazo.com/6c97d725817b16182d937d58c70a64e2
my nexus dock as you can see in the screenshot, sometimes either goes behind my windows taskbar and to get it back up i usually have to relaunch workshelf, or sometimes it just disappears completely, can you help please
 Post subject: Re: Winstep Nexus Dock keeps going behind windows 10 taskbar
PostPosted: Wed Dec 27, 2017 10:30 am
Not sure I understand what you want. You want the dock to be *overlapping* the Windows taskbar and always on top of it, but sometimes it goes behind it? Or you want the dock to be *above* the Windows taskbar, but sometimes it drops down the screen and goes behind it?
Also, why so many ? icons on your dock? What version are you running?
PostPosted: Wed Dec 27, 2017 5:49 pm
Hey, thanks for replying
I want the dock to appear when i bump the bottom (which is already setup), it should on top of the taskbar not behind it, if its behind it i cant click on it and it only clicks on the windows task bar
theres a lot of nexus icons because those are sub folders, i would prefer if the icon was dynamic and showed whats inside those subfolders if thats possible
also theres a lot of icons with a question mark because around 3 months ago i got a new computer, backed up all the settings and shortcuts and recovered it on a new computer, even though the url links to correct items the icons never refresh and maintains as question marks
heres the version information:
https://gyazo.com/a2feeba02f9591d4a448e6af97265a88
PostPosted: Tue Jan 02, 2018 8:04 pm
https://gyazo.com/35e8864861c96e461ae0ed9b3d66f6a4
Heres a picture of it appearing behind the taskbar for some reason
PostPosted: Wed Jan 03, 2018 4:11 am
Tomas, the dock was NEVER meant to run *overlapping* the taskbar. You risk having z-order problems - as you are - if you try. You can, however, make it run *above* the taskbar, by making the taskbar reserve screen space and the dock respect reserved screen space.
Unfortunately Nexus sub-dock icons are *not* dynamic, nor would it make much sense to make them dynamic because the contents of sub-docks are usually not images, videos or documents. You can still customize those sub-dock icons with static images of your choice.
Also, you seem to be running v16.3 under Windows 10. I *strongly* advise you to upgrade to the latest version, there were *many* Windows 10 related additions to Winstep software after v16.3.
PostPosted: Wed Jan 03, 2018 8:26 pm
ok that makes sence, i checked respect reserved space, should work better now
is there a way to enable an individual dock to appear on all monitors connected?
or
in preferences > dock & shelves, theres a button locate position, is there a way to have that as a shortcut? so when i tap ctrl for example it brings up the dock, as i mentioned before, when i bump the bottom of the screen it doesnt appear for some reason at all (i assume workshelf crashed or maybe its displaying on another monitor for some reason)?
thanks a lot
PostPosted: Wed Jan 03, 2018 8:45 pm
You can already assign a hotkey to a dock which makes the dock pop-up when you press it:
Dock Properties -> Behavior -> Activation Settings -> Hotkey
PostPosted: Fri Jan 05, 2018 5:56 pm
great thanks
ok regarding the icons being dynamic etc, so when i recorvered the backup of nexus from my old laptop to the new one, i changed my username from Tomas to Tom, which means some shortcuts were not recognised
but when i change the url of the shortcut to the newly corrected one, the shortcut icon doesnt update and is left with a question mark, however, this is a bit odd, since for example i have an external hard drive with lots of projects, and lots of shortcuts from that hard drive on the nexus dock, and if i do not connect the hard drive, and boot up windows, nexus wont recognise the shortcut and display a ? icon, but when i connect it, they will all update and display the correct shortcut icon, so how come the new shortcuts that i have corrected the url for and it links correctly and runs when i click on it, the icon doesnt update for say:
C:\Program Files\Microsoft Office\Office15\WINWORD.EXE
surely it should update when i click on it as it does with windows explorer shortcuts within nexus?
PostPosted: Fri Jan 05, 2018 6:14 pm
I'm not sure I understand what is going on there. To start with, could you please provide a screenshot showing an open Dock Item Properties dialog for one of the dock items displaying the question mark icon?
PostPosted: Sat Jan 06, 2018 3:58 pm
https://gyazo.com/9f41ce1f8bc3e1c72078a522eecd5f26
Here you go, so in the subdock, i have outlook, word, and excel, with live URLs, and when i click on them it works, but the icon doesnt update
however, shortcuts to windows folders, say an external hard drive, if i start my computer and the external hard drive isnt connected, the shortcuts will be dead and so is the icon, and would display a ?
but as soon as i would connect the external harddrive and click on a nexus link to a shortcut that targets the external harddrive, the icon would update
so im just wondering, how come windows explorer icons update when found but exe icons do not
PostPosted: Sat Jan 06, 2018 9:00 pm
TomasMascinskas wrote:
Here you go
Hmmm, sorry, not what I asked for. See those three question mark icons in the sub-dock? Rigth click in one of them, select 'Dock Entry Properties' in the right click context menu and then take a screenshot of the dialog that pops up.
PostPosted: Sat Jan 06, 2018 11:33 pm
https://gyazo.com/853666f5301b1f62fe60f5fa67781408
PostPosted: Sun Jan 07, 2018 6:53 am
Ok, here is what you should do: clear the Icon Path field so it's blank. Now you should always get the correct icon.
PostPosted: Sun Jan 07, 2018 5:38 pm
ahhh, excellent, thanks a lot :D
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 25 guests
