 Post subject: No Indicator for Running Applications
PostPosted: Wed Dec 20, 2017 9:57 am
I've noticed that there are times when I have an indicator for a running application and on the other hand, there are some applications that while running, have no indicator at all. Why does this happen? I want all running applications to have an indicator beneath their icon. I'm using Windows 10 Fall edition on an HP Envy laptop.
 Post subject: Re: No Indicator for Running Applications
PostPosted: Wed Dec 20, 2017 10:00 am
You will have to be a LOT more specific than that if you want a meaningful answer. :D
For instance, you will need to post a screenshot of the Item Properties dialog for one of the applications that should be showing a running indicator but isn't.
Users browsing this forum: Google [Bot], GPT [Bot] and 94 guests
