 Post subject: Disable Voice only (but sounds)
PostPosted: Fri Nov 24, 2017 8:43 am
Latest version 17.1: Preferences -> Sounds
I would disable the Voice Theme, and continue to hear the sounds.
But the only thing I can do is disable everything, using the option:
Disable all sounds and voices
How to disable only Voice?
HTH
gibra
Windows 10 Home 64bit
 Post subject: Re: Disable Voice only (but sounds)
PostPosted: Fri Nov 24, 2017 1:50 pm
If you want to disable the voice time announcement, right click on the clock and select 'Disable Time Announcement'.
Each different module has its own settings to define wether it uses sounds or voice announcements.
PostPosted: Fri Nov 24, 2017 4:06 pm
Hi winstep,
resolved.
Thank you
HTH
gibra
Users browsing this forum: Apple [Bot], GPT [Bot] and 59 guests
