 Post subject: Windows Environment Variables
PostPosted: Mon Nov 13, 2017 4:25 pm
When I create new element, I try to define it like "Folder" and fill the "Path File", for example, %ALLUSERSPROFILE% but it does not work.
Now the question is : how can i use the Windows Environment Variables instead of explicit declaration, in example above, C:\ProgramData ?
The same thing happens for the %USERPROFILE% or other Environment Variables ...
Thanks a lot !!!
P.S. : Sorry, for my bad English.
 Post subject: Re: Windows Environment Variables
PostPosted: Tue Nov 14, 2017 8:16 am
While you probably noticed several signs that environment variables were being automatically expanded *internally*, due to an oversight the SEE_MASK_DOENVSUBST flag was not being used when *launching* the actual items, which caused those variables NOT to be expanded by ShellExecuteEx.
Fixed it for next release.
PostPosted: Tue Nov 14, 2017 6:25 pm
Great !!!
PostPosted: Tue Nov 14, 2017 7:31 pm
If you want to get it a bit sooner than the official release, make sure that 'Notify me of beta (test) versions' is enabled in the Advanced tab of Preferences.
Users browsing this forum: Google [Bot], GPT [Bot] and 92 guests
