 Post subject: Modules
PostPosted: Sat Apr 01, 2017 4:58 pm
Jorge, while I love the recent addition to save module positions, it would be awesome if maybe in the next release you could allow for nudging modules into a precise position via the arrow keys on the keyboard?
I apologize if this has already been covered elsewhere.
Jim Dillard
 Profile YIM
 Post subject: Re: Modules
PostPosted: Sun Oct 08, 2017 8:21 pm
Well, more control over module positioning will be nice indeed.
PostPosted: Wed Oct 25, 2017 3:48 am
I've asked for this and/or the ability to make modules "click" together. The problem with having them snap to each other is that there has to be some way to tell them where to snap, and all modules in a given theme need to be able to snap to any other module. I've fallen back on using a zoom app wherein the app shows the area around my cursor zoomed in. I use Xoomer, which is free, to do this.
http://www.brothersoft.com/xoomer-77517.html
PostPosted: Tue Oct 31, 2017 2:48 pm
Ok, added the ability to move desktop modules pixel by pixel via the arrow keys. It will use the system's keyboard key repeat rate if you keep the arrow key pressed.
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot] and 110 guests
