 Post subject: App crash when Connecting HDMI
PostPosted: Thu Aug 03, 2017 7:17 pm
Several times now workshelf crashes when connecting to TV via HDMI.
Win 7 64 bit, TV is set as primary monitor (so i can run a game on it) an after TV connects and takes over as primary winstep soon crashes
problem signature:
Problem signature:
Problem Event Name: APPCRASH
Application Name: WorkShelf.exe
Application Version: 17.1.0.1212
Application Timestamp: 588b25a4
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.23807
Fault Module Timestamp: 5915f8e8
Exception Code: c0000005
Exception Offset: 00058a5b
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
 Post subject: Re: App crash when Connecting HDMI
PostPosted: Sun Aug 06, 2017 1:32 pm
Problem signature:
Fault Module Name: StackHash_8882
Exception Code: c0000374
Exception Offset: 000ce8fb
Locale ID: 2057
Additional Information 1: 8882
Additional Information 2: 8882fe1107d256aa2aff44dd58f2bd39
Additional Information 3: a4ac
Additional Information 4: a4acc5144c1fcc1d0de7004451123137
PostPosted: Mon Aug 21, 2017 4:54 pm
Does the problem also happen if you switch the primary monitor with both the monitor and tv connected?
PostPosted: Mon Aug 21, 2017 6:42 pm
thik so, ill be able to check tomorrow (dont have acces to the tv now)
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 24 guests
