 Post subject: Question about the Nexus Ultimate backup
PostPosted: Thu Jun 15, 2017 1:45 pm
Hi, I would like to know if the backup that it is provided in the advanced tab does backup only the settings, and not the icons that I have organized in the dock, with the names and all. So if I do a backup and reset my computer (format), when i use the backup, does it come with all the icons that I have setup?!?! With the names and folders?!?! And also once I've reset my computer, how to I use the backup file?! Thanks for all the support in advance, the Nexus Dock is really nice.
 Post subject: Re: Question about the Nexus Ultimate backup
PostPosted: Thu Jun 15, 2017 7:04 pm
it backups shortcuts, docks,sub docks, (names,locations/paths) but not icon/themes images themselves, so you'll have to manually backup all custom icons/themes/images
you just use the restore option from advanced options to load the settings, and as long your icons/programs/files are in the same locations/folder structure everything will be as it were
PostPosted: Fri Jun 16, 2017 12:25 am
Thank you for the support!
Users browsing this forum: Amazon [Bot], GPT [Bot] and 45 guests
