 Post subject: Fat systray
PostPosted: Sat Nov 24, 2007 11:22 pm
Something strange happened recently with my floating systray. Normally, it's a single line of icons, but after some game ran recently it changed to 3 lines of 5 icons each with a giant systray button:
Any idea how to fix that? I didn't see any settings for number of icons per row or anything like that.
Thanks,
-Eric Gooch
www.cybergooch.com
PostPosted: Sun Nov 25, 2007 10:58 am
Hi Eric!
Be careful! You need to put your systray on a low-fat diet as fast as possible before it bursts, which has the nasty effect of spreading systray icons all over your desktop! :wink:
Seriously, temporarily disable NS Task Management to get the real Windows taskbar back, re-size or move it so the systray is a single row of icons once more, and re-enable NS Task Management.
Users browsing this forum: Google [Bot] and 73 guests
