 Post subject: choose which system try items to show
PostPosted: Mon May 08, 2017 3:11 pm
at thre moment i can not choose which icons to show as system tray icons.
it is either al or notrhing.
this makes no sense since i want to be able to choose which icons show up in the system tray
 Post subject: Re: choose which system try items to show
PostPosted: Mon May 08, 2017 10:06 pm
Use Windows to choose what you want to see on the collapsed systray. It already has a tool that allows you to do exactly that (click 'Customize' on the expanded systray window), so there was no point in re-inventing the wheel. :)
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot], Majestic-12 [Bot] and 80 guests
