 Post subject: Clean Orphan (+ dead) Systray Icons in the cache (Solved)
PostPosted: Thu Mar 30, 2017 1:20 pm
How should I properly clean the Systray Icons cache ?
I see many "Orphan" icons and also many from programs that have long since been uninstalled.
How would I clean and remove unwanted items correctly ?
Must I go through the folder and remove them manually & individually ?
 Post subject: Re: Cleaning Orphan (and dead) Systray Icons in the cache ?
PostPosted: Thu Mar 30, 2017 3:58 pm
No.
Open Preferences, go to the Advanced tab, Troubleshooting Options button, Reset Tray Cache button.
Voila! :)
PostPosted: Thu Mar 30, 2017 7:37 pm
Thanks, that worked !
I can`t even recall seeing that specific settings page before ! :shock:
(I did have to manually click "Restore Original" on a lot of Orphans before they were removed from the list inside the program - even though the physical folder was cleaned of .pngs)
Users browsing this forum: Apple [Bot] and 56 guests
