 Post subject: Arguments for a URL shelf item?
PostPosted: Mon Mar 20, 2017 9:40 pm
I'm pretty new to Winstep Xtreme, so forgive me if this is obvious.
I have a shelf that I've added a URL item to. I need to pass some arguments into the URL, but the Arguments field is grayed out. Is there a way I can pass arguments in on the URL field line? Is there some other way to pass in arguments? Am I missing something?
Thanks!
 Post subject: Re: Arguments for a URL shelf item?
PostPosted: Tue Mar 21, 2017 8:06 pm
The arguments should be put in the URL field itself, just as you would when typing that URL into a browser's address box. For instance, like this:
Code:
http://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=10430
The URL is
Code:
and the arguments are
Code:
?f=2&t=10430
Just put everything together in the URL field.
PostPosted: Tue Mar 21, 2017 9:27 pm
That works great! I'm embarrassed to say that I didn't try that earlier. :oops:
PostPosted: Tue Mar 21, 2017 11:05 pm
Eheh. No worries. :D
Users browsing this forum: Amazon [Bot], Google [Bot] and 69 guests
