 Post subject: Export NextStart setting
PostPosted: Tue Mar 14, 2017 9:15 am
Hello,
is ist possible to export my nextstart settings and design, when i move
from windows7 to windows10?
Thank you.
 Post subject: Re: Export NextStart setting
PostPosted: Tue Mar 14, 2017 9:20 am
Themes and the application itself will have to be re-installed, but you can export NextSTART settings by opening NextSTART Preferences -> Advanced tab -> Backup.
Save the file into a USB pen or floppy.
Once Winstep Xtreme is installed on the new system, open NextSTART Preferences -> Advanced tab -> Restore, to restore settings from the file you previously saved.
For WorkShelf it is a similar procedure. Don't forget NextSTART and WorkShelf are independent applications, so you will have to backup (and restore) NextSTART and WorkShelf settings separately.
PostPosted: Tue Mar 14, 2017 9:54 am
Thank you,
i will try.
Users browsing this forum: Amazon [Bot], Google [Bot] and 56 guests
