 Post subject: Folders with no text, just icons
PostPosted: Sun Feb 19, 2017 7:50 am
When I open a folder from the dock with a long left click, is there any way to get those shortcuts listed inside the folder as icons only and not icons with text?
 Post subject: Re: Folders with no text, just icons
PostPosted: Sun Feb 19, 2017 7:54 am
Using the free version of Nexus? No.
Using Nexus Ultimate or Winstep Xtreme? Yes.
PostPosted: Sun Feb 19, 2017 4:07 pm
I purchased Xtreme in 2013...that is what I am running.
PostPosted: Sun Feb 19, 2017 4:26 pm
... and you renewed today too. Ahem. :)
Ok, so you know about sub-docks already right? That is one solution to the problem, but sub-docks do not display the contents of folders. The Shelf does, but I guess that's not what you want either.
What you want is called Stacks, which is one of the things I'm currently working on for the next release. Great timing - this way you can provide some much needed feedback. :)
Can you go over the topic I link above (the 'What's new after v17.1') and please let me know what you would like to see in the Winstep implementation of the Stacks docklet?
PostPosted: Sun Feb 19, 2017 8:35 pm
Will do! Glad to help.
Users browsing this forum: Majestic-12 [Bot] and 24 guests
