 Post subject: Problems with reconfiguration Nexus after system crash
PostPosted: Thu Nov 03, 2016 12:55 pm
After system crash I have to restore all files, also Nexus Ultimate. But without to become too stressful, I have full access to the old files and tried to copy the content from the old to the new Winstep-folder but without results. So where are the informations about my Nexus configuration? By Stardock it's an simple ini-file, but I can't find anything there. Someone who can help me, maybe I'm blind.
Tx
 Post subject: Re: Problems with reconfiguration Nexus after system crash
PostPosted: Thu Nov 03, 2016 1:06 pm
Like most applications, Nexus stores settings in the Windows Registry, not on INI files.
This is one of the reasons why it has backup and restore functions in the Advanced tab of Preferences - those will save settings to a text file or restore from one.
If you never used the Backup feature I'm afraid you will have no choice but to re-construct your old setup from scratch, sorry. :(
PostPosted: Thu Nov 03, 2016 8:01 pm
@winstep
Thanks for helping me, any suggestion where I have to search in the registery? Maybe I can reimport the config.
brennwert
PostPosted: Thu Nov 03, 2016 9:46 pm
Settings are stored under
HKEY_CURRENT_USER\Software\WinSTEP2000
PostPosted: Tue Nov 08, 2016 12:18 pm
@Jorge
Tx for your help, but my idea is garbage, because I've found a way to open the other registry, but I can't find the path to the winstep-settings in there. I'm afraid I have to rebuild from new.
Sorry for the hassle.
Users browsing this forum: Apple [Bot] and 14 guests
