 Post subject: Re: Nexus fails to pin apps from Windows Store
PostPosted: Wed Nov 29, 2023 7:50 pm
Try the following method:
1.- WIN+R to open Run.
2.- Type: Shell:AppsFolder and press Enter
3.- It will show the "Applications" folder with all the programs installed in the system. Including UWP.
4.- From that folder drag and drop the selected program into the dock.
NOTE
As you can see in the Windows folder itself some applications are shown without icon.But access from the dock works.
Simply in those that do not show icon, right click and in Properties of the element > Change Icon
In Properties > File = the AppUserModelID (AUMID) of the UWP application is displayed.
AppUserModelID:Clipchamp.Clipchamp_yxz26nhyzhsrt!App
231129 NU 22.7_Applications_Propiedades_Cambiar icono.png [ 161.54 KiB | Viewed 36854 times ]
231129 NU 22.7_Applications_Arrastrar y soltar en dock.png [ 185.77 KiB | Viewed 36854 times ]
PostPosted: Thu Nov 30, 2023 3:35 am
Solving a problem where none exists / where issue has long been addressed....
Semper usque ad finem bibendum!
"Always let us drink to the very end!" - It's all one can do in this age.
PostPosted: Thu Nov 30, 2023 7:11 am
I did ask how to open the AllApps folder. :D
Anyway, tried dragging Paint here (23H2 now) from that folder to the dock, no issues. Sounds like the problem is in the original OP's system.
PostPosted: Thu Nov 30, 2023 3:39 pm
Sorry¡¡¡¡
I assume that as Moderator you can remove it if you feel like it.
PostPosted: Fri Dec 01, 2023 2:30 am
Sorry¡¡¡¡
Yes, I could indeed but there's no compelling reason to do so, and more so in light of user 'Winstep''s reply above. :)
PostPosted: Tue Jan 23, 2024 3:54 pm
I found out another thing. Rightclicking the running app icon and choose "Pin to dock" from the popup menu fails for Windows Store apps.
:Moderator's note: Spam removed. :/Moderator's note: - nexter
PostPosted: Tue Jan 23, 2024 5:55 pm
dronycroin wrote:
I found out another thing. Rightclicking the running app icon and choose "Pin to dock" from the popup menu fails for Windows Store apps,
Ok, give me an example of a Windows Store App that Pin to Dock fails with, please.
Also, what version and build of Windows are you running?
PostPosted: Wed Jun 26, 2024 3:43 pm
I found a work around. First of all, it seems to be caused by having Preview Builds installed. What I did was locate the apps exe itself and take ownership. I then added a dock item and pointed to the apps exe file. Hope this helps!
Users browsing this forum: Google [Bot], GPT [Bot] and 39 guests
