Board index : Winstep Forums : General Discussion  [ 30 posts ] Go to page Previous  1, 2
 Post subject: Re: When?
PostPosted: Tue Sep 08, 2020 1:05 pm
i really like your windows scheme, what software are you using for that?
PostPosted: Tue Sep 08, 2020 3:08 pm
Thanks.
Currently I'm using a combination of Winstep (obviously...), Windowblinds 10, Start10 and 7+ Taskbar Tweaker. Looks like this at the moment:
PostPosted: Wed Sep 09, 2020 4:52 pm
Is the clock on the wall a live clock? If it's a live clock, what program are you using for that and which skin?
PostPosted: Wed Sep 09, 2020 5:53 pm
i believe itsa a whinstep clock one of the skins, dont remember the name
PostPosted: Thu Sep 10, 2020 1:44 pm
That would be "Cabal". A very cool theme.
PostPosted: Sat Sep 12, 2020 1:04 pm
Yep, the clock is from the "Cabal Xtreme" theme.
Tried everything I can think of except reinstalling now, don't know if that might help with my problem?
Any other way to get access to the latest beta? Would really like to try it out. And it does feel kinda pointless just having renewed the subscription and not being able to update...
PostPosted: Sat Sep 12, 2020 6:20 pm
Click the box and recheck for updates:
PostPosted: Sat Sep 12, 2020 10:00 pm
Thanks for the tip, but as shown in screenshots and mentioned in my posts on page one, those are already checked.
I've unchecked them, rechecked them, exited Winstep, started it again, restarted computer, checked startup- and firewall settings, checked for updates several times for a few days now, etc, to no avail.
I still only get the message that "All Winstep applications installed are currently up-to-date" and I get no notifications about beta versions. That's the problem.
PostPosted: Sun Sep 13, 2020 3:42 pm
If you're up to date then you're up to date.
PostPosted: Mon Sep 14, 2020 1:23 pm
Yep, it sounds like you're already using the latest beta.
PostPosted: Mon Sep 14, 2020 4:28 pm
Whats the number you have got in the settings?
oOSGearOo Aka Steve....
Technobable
PostPosted: Tue Sep 15, 2020 5:16 pm
I'm using the beta.
PostPosted: Tue Sep 15, 2020 9:43 pm
AlDollaz wrote:
I'm using the beta.
then your upto date the release will come
Technobable
PostPosted: Wed Sep 16, 2020 1:36 pm
Thanks, but I think it was someone else asking.
PostPosted: Wed Oct 28, 2020 8:45 am
v20.10 has just been officially released. :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 30 posts ] Go to page Previous  1, 2
Users browsing this forum: Amazon [Bot], Apple [Bot] and 168 guests
