 Post subject: Winstep releases Winstep Xtreme 7.9!
PostPosted: Fri Sep 28, 2007 6:19 pm
Winstep is proud to announce the release of Winstep Xtreme v7.9 Final.
Screenshots:
ImageImage Image
Winstep Xtreme is a complete integrated Desktop Environment featuring the next generation of award winning Winstep user interface enhancements.
You can download the new Winstep Xtreme 7.9 version from HERE.
So what is new in Winstep Xtreme 7.9? Well, we listened carefully to your suggestions:
Faster startup times: Winstep applications now initialize much faster than previous versions!
Improved Module Performance: The display of desktop and in-shelf modules has been fully optimized to use as little CPU as possible.
New default sounds: The previous default sounds were replaced with a less intrusive and cooler set of new sounds.
CPU Module support for multi-processors: The CPU meter module now properly supports multi-processor systems.
NeXuS Tasklist icon blink: NeXuS tasklist icons now blink when the associated application needs your attention.
Weather Forecast on Desktop Weather Module: The desktop weather module is now capable of displaying the 5 day forecast on the module itself (note: this feature is theme dependent). Previously the forecast was displayed on the information tooltip only.
Improved Windows Vista support: the new versions fix some issues on Windows Vista 32 bit.
and much, much more!
There are lots of other additions and fixes in this awesome new release. You can see a complete list of changes to the WorkShelf and NeXuS component of Winstep Xtreme HERE and to the NextSTART component HERE.
Users browsing this forum: No registered users and 19 guests
