 Post subject: NextSTART v3.2 and WorkShelf v1.6 Released!
PostPosted: Fri Aug 20, 2004 8:08 pm
Winstep Software Technologies releases NextSTART v3.2 and WorkShelf v1.6!
Among many other improvements and fixes, the new releases fix a troubling bug with the multi-monitor code that prevented both NextSTART and WorkShelf from running properly on NT4/Win95 systems. With most, if not all, skinning applications moving away from NT4/Win9x and specializing in XP only, Winstep software is probably one of the last Windows customizing software that still supports these early versions of Windows.
New Features in NextSTART v3.2:
* Taskbar buttons now flash when Messenger windows try to get the user's attention.
* Startbar automatically reserves screen space so maximized windows don't cover it.
* Menus too long to fit on the screen can now be displayed in side-by-side panels.
* Added support for capturing the new WorkShelf modules into the startbar.
* Startbar tasklist can now be scrolled up and down using the mouse wheel.
* Better transparent systray support under XP.
* Automatic middle mouse button emulation can now be turned off.
Bug Fixes in NextSTART v3.2:
* NextSTART now runs properly under NT4/Win95.
* Bug that prevented the use of more than 36 hotspots.
* Deleting the last item of a menu in the Menu Editor would crash NextSTART.
* Hotspot button right click context menu could sometimes fail to pop up.
* Tasklist sometimes displaying blank icons.
* Cancel would not discard changes made in the Menu Editor.
* Lots more of new features and bug fixes!
For a complete list of changes and additions, please click here:
http://www.winstep.net/history-ns3.txt
New Features in WorkShelf v1.6:
* New Explosion animation when an item is deleted from the shelf.
* WorkShelf automatically positions itself on the screen so it does not cover or is covered by the NextSTART startbar.
Bug Fixes in WorkShelf v1.6:
* WorkShelf now runs properly under NT4/Win95.
* Tray icon was not being added to the systray after an Explorer crash.
* Recycle bin problem with a specific Shell32.dll version.
http://www.winstep.net/history-ws.txt
System Requirements:
WorkShelf and NextSTART will run under Win95/98/ME and NT4/2000/XP.
Users browsing this forum: No registered users and 22 guests
