 Post subject: Winstep Xtreme v10.9 Released!
PostPosted: Thu Oct 14, 2010 4:22 pm
An integrated workspace environment, Winstep Xtreme is a powerful suite of applications that merge incredible usability and performance with breathtaking eye candy.
Winstep Xtreme runs on the 32 and 64 bit versions of Windows 2000, XP, 2003, Vista and Windows 7 and is currently available in the following languages: Bulgarian, Chinese (Simplified), Czech, Dutch, English, Farsi (Persian), French, German, Italian, Korean, Norwegian, Portuguese, Portuguese (Brasil), Russian, Serbian, Slovak, Spanish.
The v10.9 release is a major release. Feature highlights:
◦Added new Squish, Spin, Sonic Boom, Heal, Fire, Magic, Flare, Wind and Water mouseover effects to docks and the Shelf:
◦New particle mouseover animations can be colorized for thousands of different variations
◦Each mouseover effect now has its own independent settings, such as magnitude, duration and color
◦Added new Fire, Flare, Heal, Explosion and Magic menu opening animations:
Image Image
◦Added 'Do Not Launch Multiple Sessions' setting to the Misc.Advanced dialog so clicking on a shortcut of a running application brings that application forward instead of launching a new instance
◦Added window thumbnails with peek ability that pop up when mousing over icons of running programs:
◦Sub-docks can now be set to open parallel to the parent dock, instead of perpendicular.
◦Sub-docks can now be set to open automatically on mouse over.
◦Icon reflections can be optionally disabled on vertical docks and sub.docks to make them more compact.
◦Dock can now be prevented from comming forward by accident when bumping the screen edge by enabling the new 'Disable edge activation' setting
◦Wallpapers can now be applied automatically when switching to a new theme
◦Explosion Animation, shown when an item is deleted, can now be disabled
◦Balloon tooltip now display thumbnails of document and video files
◦Dock alignment can now be set by dragging the dock horizontally or vertically
◦Color of item labels can now be changed
◦Added support for Bulgarian, Chinese (Simplified), Korean and Norwegian languages
◦Much more!
Users browsing this forum: No registered users and 19 guests
