 Post subject: NextSTART Corporate v3.1 Released!
PostPosted: Sat Mar 27, 2004 3:24 pm
NextSTART Corporate is a powerful, skinnable, and dynamic pop-up menu that can be used as a secure replacement to the Windows Start Menu and Interface. Ideally suited for Internet cafes, Libraries, public access terminals and corporate use, NextSTART Corporate Edition offers a range of features for improving productivity and ease of use, whilst preventing unauthorized modification of the PC's interface by end users.
With NextSTART you can conveniently access all your programs and files using a highly structured and completely customisable menu tree system. Menu configuration is a breeze with full support for drag & drop. Tear off sub-menus can be conveniently left open and placed anywhere on your screen while you work on related tasks. Winstep’s hotspot technology allows you to quickly open menus and launch programs by bumping screen edges and corners with the mouse cursor or by clicking anywhere on the desktop and other application windows. Above all, NextSTART is very easy to configure, providing a full-blown GUI Preferences screen.
* Allows the design of a common interface for all Windows PC's that reflects your corporate identity.
* Permits quick and intuitive access to those functions and applications that your users need.
* Secure, password-protected configuration panel prevents unauthorized modification of NextSTART Corporate Edition's interface.
* Far easier to use than the standard Windows interface.
* Improves productivity.
* Rapid access to applications and system utilities.
* Fast menu-based file browsing.
* Multi-lingual support.
* Multi-user support.
* Multi-monitor support.
* Enable/disable the powerful task management and system tray support dependent on the needs of your users.
Customer Comments:
"We're back from our meeting, and our Web Cafe was a resounding success, we had more people come through than any of our previous shows. NextStart Corporate worked like a charm, as well as your utilities. We were able to setup all 80 of our computers in a matter of minutes using the configuration import."
"Thanks so much for your help and excellent service -- not to mention a program that no one can beat in both features and price!"
Douglas Marcus
Internet Technology Manager
American Urological Association
"I am convinced that NextSTART was the right solution for our problem (thank you Jimmy for finding it!) and I am happy to see that the Corporate (secure) version is now available and working. Thank you again also for your support now and back then when I was in China with Jimmy."
Francois Arseneault
Supervisor, Systems Architecture
Bombardier Transportation
System Requirements:
NextSTART Corporate will run under Win95/98/ME and NT4/2000/XP.
Download NextSTART Corporate from:
http://www.winstep.net/index.asp?cat=nscorporate
Users browsing this forum: No registered users and 5 guests
